FujiXerox Error code 041-356 / Model DCVIIC 3372
  • NanthaK
    • Nov 2019
    • 3
    [Error Code] FujiXerox Error code 041-356 / Model DCVIIC 3372
    Hi members, .please advice me how to solve the above mentioned error code on FujiXerox MFP.
    i replaced the Motor Drive PWB, but the fuse 11 blow again & again.
    Please advice me on this.
    Thankyou
    Nantha
    Re: FujiXerox Error code 041-356 / Model DCVIIC 3372
    Thankyou
    Nantha
    I would suggest following the RAP for the code.
    Xerox is VERY particular in their repair actions..
    follow the MANUAL to the LETTER.
    have u checked the voltage on the harnesses to/from the PWB that you replaced?
    check the harness for cuts/pinches/extreme bends/crimps in any of the harnesses involved?
    report back
    Phil B. ' The Dentist '
    • NanthaK
      • Nov 2019
      • 3
      I will follow the instruction.. thank u
      • NanthaK
        • Nov 2019
        • 3
        report back
        Thankyou. will follow the steps.
        • elsab
          • Dec 2007
          • 63
          Thankyou
          Nantha
          041-356 Motor Drive PWB F11 Fuse Fail [IMG]file:///C:/Edoc/common_e2/images/full_a.gif[/IMG]
          Bsd-on:CH1.13, CH1.6, CH1.9, CH6.11
          [IMG]file:///C:/Edoc/common_e2/images/description.jpg[/IMG] Fuse 11 on the Motor Drive PWB has blown.
          [IMG]file:///C:/Edoc/common_e2/images/note.jpg[/IMG]This Fail is the Sub System Fail and when this Fail occurs, +24VDC_C13 and +24VDC_Intlk will be cut off. (Refer to BSD CH1.8, CH1.10)
          Procedure
          Turn OFF the power and remove the Rear Lower Cover. Measure the resistance of the Motor Drive PWB (F11).
          Is the resistance 5 Ohm or higher?
          Yes No
          Check the connection between the LVPS_CP1U J509-2 and the Motor Drive PWB J400-1 for open circuit, short circuit, and poor contact.
          Disconnect the following connectors from the Motor Drive PWB and measure the resistance between each connector terminal and the GND.
          • J411-3 (1ST BTR CONT/RET Sensor)
          • J416-4 (Temp & Humidity Sensor)
          • J416-12 (ADC Sensor)
          • J417-3 (Toner Container Position Sensor)
          • J417-6 (Toner Container Full Sensor)
          • J418-18 (ATC Sensor Y)
          • J420-1 (Fusing Unit Exit Sensor)
          • J420-4 (P/Roll Latch Sensor)
          • J420-9 (Belt Speed Sensor)
          • J424-3 (ATC Sensor K)
          • J424-6 (ATC Sensor M)
          • J424-9 (ATC Sensor C)
          • J425-5 (T1 Level Sensor)
          • J425-8 (T1 No Paper Sensor)
          • J425-11 (T1 Lever Position Sensor)
          • J425-16 (T1 Pre Feed Sensor)
          • J428-4 (T2 No Paper Sensor)
          • J428-9 (T2 Pre Feed Sensor)
          • J428-10 (T2 Lever Position Sensor)
          • J428-12 (T2 Level Sensor)
          • J431-B6 (Regi Sensor)
          • J431-B9 (POB Jam Sensor)
          • J431-B12 (MSI Feed Out Sensor)
          • J433-3 (Exit 2 Sensor)
          • J433-4 (Exit 2 OCT Home Position Sensor)
          • J433-12 (Face Up Exit Sensor)
          • J433-17 (Exit 1 OCT Full Stack Sensor)
          • J435-1 (Exit 1 OCT Home Position Sensor)
          • J435-6 (Exit 2 Tray Sensor)
          • J435-10 (NOHAD Temp & Humidity Sensor)
          • J435-13 (Exit 1 Tray Sensor)
          • J436-A4 (MSI No Paper Sensor)
          • J436-A7 (MSI Nudger Position Sensor)
          • J443-6 (Rear MOB Sensor)
          • J443-12 (Front MOB Sensor)
          • J451-1 (T3 Feed Out Sensor)
          • J451-4 (T3 Level Sensor)
          • J451-7 (T3 No Paper Sensor)
          • J451-12 (T3 Pre Feed Sensor)
          • J451-13 (T3 Lever Position Sensor)
          • J452-9 (2TM Takeaway Motor)
          • J454-5 (T4 Feed Out Sensor)
          • J454-6 (T4 Level Sensor)
          • J454-9 (T4 No Paper Sensor)
          • J454-14 (T4 Pre Feed Sensor)
          • J454-15 (T4 Lever Position Sensor)
          Is the resistance 5 Ohm or higher for all?
          Yes No
          Check the following:
          • The connections that are in earth fault (at 5 ohm or lower) for short circuits.
          • The target components for internal short circuits.
          Replace the Motor Drive PWB. (PL 18.2)
          • shinchan
            • May 2011
            • 199
            Thankyou
            Nantha
            I attached the error code according to the manual.
            Try making sure the power source / power outlet on the wall is giving stable voltage of 220v.
            • tselkasa
              • Apr 2024
              • 2
              Hello Nantha, Is your machine OK? I have the same problem with the DC VI C3370 machine, any one help please?
