xerox 7545 dadf problem
  • markuss100
    • Feb 2018
    • 16
    [Misc] xerox 7545 dadf problem
    i have a xerox 7545 and i have a problem in the dadf i changed a new one but i still get this error plus i changed the pwb scanner board that the dadf connects to +the board in the dadf and still have this message upon putting a paper in the doucument feeder
    the error says choose doucument feeder or doucument glass
  • jhalfhide
    • Apr 2015
    • 451
    Re: xerox 7545 dadf problem
    This is usually when the black plunger isn't being pushed far enough when the DADF is closed onto the glass. Lift document handler and check black plunger at back left corner. Stick a spacer above it
    Sent from my LYA-L09 using Tapatalk
    • markuss100
      • Feb 2018
      • 16
      my friend i just solve my problem u see i have like in my place high lighting so when i was tired of fixing so i took the lights off and about to turn it off it started working u see lighting does affect sensors and when i closed the dadf it worked altho when i did put the old parts back the problem did got back from the sensor document set was damaged
      so to counclude this lighting does affect when its so high and bright so covering sensors when its working might be a good idea and ty for replying
