DC5252 System Software
  • Jake2o
    • Dec 2007
    • 325
    Does anybody have DC5252 system software? (I don't need pws or the download tool, just the 5252 software)
    And
    Does anybody know if you can use a UI off a 2045/2060 on an 5252?
  • Milo Wilson
    • 504
    Yes you can use the 2045/60 monitor, but you will have to do a DC132 then reboot. You will probably have to change the splash screen NVM setting and covers since the 5252 is blue .
    • Jake2o
      • Dec 2007
      • 325
      Do you know which NVM needs to be changed?
      • Milo Wilson
        • 504
        DC5252
        UI PWBA Software Download
        1. Right mouse click in the Download File List to activate a pop- up menu.
        2. Select Delete All to clear the contents of the Download File List.
        3. Download the UI PWBA software.
        a. Click Connect.
        b. Select the CD- ROM Drive by clicking on the Drive pull down, then scroll to the drive where the software is located. If the CD- ROM drive letter is already displayed but not highlighted, click on the drive letter to highlight it.
        c. Use the Set Version pull- down arrow to select DC5252 IOT v7.1.4.
        d. Select the Language. If the correct language is displayed, click on the language.
        e. Select the Machine Type Copier or Printer.
        f. Click Load List, the files will be displayed in the Download File List window.
        g. Right mouse click in the Document File List to open a pop- up menu.
        h. Select Remove Existing to select only those files that differ from the currently loaded versions.
        i. Click Start Download. Select Yes to continue.
        j. Click OK when the Download Completed Successfully message is displayed.
        k. Click the Disconnect button to exit the download tool. The machine will return to the customer mode.
        4. Exit the Download Tool.
        5. After the User Mode screen (Ready to Print, Ready to Scan to Print) appears and the machine power on cycle has completed, switch the IOT off, wait 15 seconds and switch the power on.
        NOTE: A 3- 397 Dongle Broken fault may be displayed. This message will go away when the following steps are performed.
        6. Enter the Diagnostic mode again.
        CAUTION
        Do not select initialize UI PWBA.
        7. Select DC301 NVM Initialize. Select UI Subsystem. Select Start to Initialize. Select Yes to confirm.
        8. Select DC131 and reset the NVM to the Values identified in Table 1.
        Table 1 Reset NVM Values
        Chain-Link
        Value
        Description
        700-075
        0 = Off
        1 = On
        Auto Tray Switching
        700-077
        2 XC DC2060
        2 XC DC2045
        2 XC DC5252
        3 XE DC2060
        3 XE DC2045
        3 XE DC5252
        700-082
        0 = 2045
        1 = 2060
        2 = 5252
        Greeting Screen
        700-086
        XC = 0
        XE = 0
        Reduction/ Enlargement Preset 1
        700-087
        XC = 3
        XE = 4
        Reduction/ Enlargement Preset 2
        700-088
        XC = 5
        XE = 8
        Reduction/ Enlargement Preset 3
        700-089
        XC = 13
        XE = 14
        Reduction/ Enlargement Preset 4
        700-090
        XC = 18
        XE = 18
        Reduction/ Enlargement Preset 5
        700-091
        XC = 20
        XE = 20
        Reduction/ Enlargement Preset 6
        • Jake2o
          • Dec 2007
          • 325
          5252 Software
          I have the EPC Download tool, but I do not have the 5252 software.
          • Milo Wilson
            • 504
            5252 software
            I can send you the software for 5252 for $250.00 US. Use my email to send it through Paypal and when it goes through, I will send it to you over internet.
            Milo
            • mrizkhan
              Re: DC5252 System Software
              I have a message on my DC 2060/5252 UI Screen " Component Failure Imminent Dry Ink Dispenser ", The Magenta Dry Ink Dispenser will fail soon, I have checked all connections are OK with motors, I check no blockage, I checked Tonner is in reservour, seems like system software error , I do have PWS software BUT donot know how to check if there is error due to IOT software problem, I need help I hope someone will guide me. Thanks
              Kind regards
