Driver options window is to small
Re: Driver options window is to small
It appears you are refusing to post your in the proper copier forum, https://www.copytechnet.com/forums/xerox/, try paying for a support call with Xerox. It is their driver. It is their problem to fix. -
My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.Comment
This might be helpful.
On some of the Windows 10 CPU that I installed the Fiery Driver on the Printing Preferences Dialog Box comes up really small. You can print using it but you have to move the tabs up/down. I've tried a few thing but can't get itComment
no i saw this on windows 8.1 too.My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
maybe this was helpful too:
it is in german but you can translate:
