XEROX 7228 Workcenter Error code 004-346
  • mmind
    • Jul 2025
    Dear All can any one tell me solution for this Error please XEROX 7228 Workcenter code 004-346 waiting for your kind replays
  • xcopytech
    • Aug 2006
    • 1794
    04.346, 04-562 Transfer Belt Home
    The IBT Home Sensor does not detect the Belt Home signal.
    If this fault is declared 3 times in succession, print mode will be disabled. In order to
    clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
    • elder_barnes2008
      What is the NVM number?
      I have a WC M24 which is compatible to the above series. I am needing the NVM chain link to reset the IOT/FINISHER 1221 to 0.
      Thanks, any help will be greatly appreciate.
      • elder_barnes2008
        • elder_barnes2008
          Thanks, any help will be greatly appreciate and how do you search for these. My copier does not display them. I am have to search the internet for chain link number for the fault code.
          elder_barnes2008@yahoo.com
          • xcopytech
            • Aug 2006
            • 1794
            M24 is not same machine as 7228.
            M24 do not have same diagnostic as 7228.
            If you have 004-346 fault you need to reset NVM 741-056 to 0
