Xerox DC IV-C2263 error code 093-320
  • Hay Sopheak
    • Oct 2019
    • 14
    Xerox DC IV-C2263 error code 093-320 how to fix? Any one have service manual ? please help me
  • aalex_bom
    • Jan 2008
    • 214
    Re: Xerox DC IV-C2263 error code 093-320
    Fault Code 093-320: Dev Motor (Y, M, C) Revolution Failure was Detected
    • Dech
      • Aug 2014
      • 48
      I've had( look at the attachment, no 9) a tooth break on the no 9(link guide assy) in attachment. Its a black slider shaft that engages the colour dev units. Or the clutch in the no 2 ( main drive assy) is slipping..
      • nochick
        • Jan 2012
        • 80
        error code 093 is most I have found on site 100% from R1 area , toner all over that. just vacuum it until u can move gear easy with your hand.
        if it's not work you will to vacuum from rear mother board (remove mother board 1st) and that where u have to clean, Good luck
        • Hay Sopheak
          • Oct 2019
          • 14
          thank you now normal operation
