Xerox C75 Excessive Toner
  • cpress
    • 37
    Hello,
    My C75 seems to be using a lot of Black toner. Even on light coverage its using a cartridge up fast! Way more than it has in the past. Any ideas as to what I can look at to correct this?
    TIA,
    David
  • shinchan
    • May 2011
    • 194
    Re: Xerox C75 Excessive Toner
    my suggestion is to check the developer
    • Tecnico_Xerox
      • Jan 2019
      • 54
      Hi there,
      I suggest that you perform a xerographic maintenance on the equipment, clean the toner density sensors and then calibrate the printer using the Max-Setup. after that you carry out the calibration of the Server with the densitometer.
      Many times the lack of maintenance causes the equipment to saturate and waste more toner than normal.
