Versant 2100 not powering up
  • Ragnarsson
    • May 2009
    • 35
    Re: Versant 2100 not powering up
    do an altboot firmware install
    • azehnali
      • Nov 2009
      • 679
      are you sure you reconnected all the plugs and you have 220 volts
      • Ragnarsson
        • May 2009
        • 35
        All plugs connected and tested, every switch checked and rechecked
        Best regards,
        B
        • azehnali
          • Nov 2009
          • 679
          unless you blow the power supply I dont see how the machine could do this when it was working fine before the move
          • Jack79
            • Jul 2014
            • 312
            First step should be to reload fw like Phil mentioned. Your hdd might go bad too.
            • Ragnarsson
              • May 2009
              • 35
              • adriansto
                • 2383
                Go to 2.2.2 chapter in service manual and follow the procedures.
                Start with 2.2.2.4 procedure.
                • azehnali
                  • Nov 2009
                  • 679
                  does the display show any progress when you boot up or completely dead?
                  do you see any lights on the ess board?
                  any fans?
                  any sign of life?
                  • Ragnarsson
                    • May 2009
                    • 35
                    • azehnali
                      • Nov 2009
                      • 679
                      then you have power supply issues or connector
                      start checking power and connectors
                      • Ragnarsson
                        • May 2009
                        • 35
                        What we have done so far
                        - Checked all connectors
                        - Swapped the Low voltage supply 1 and 2
                        - Checked all the connectors.
                        - Checked all fuses that we saw
                        Best regards,
                        BRR
                        • azehnali
                          • Nov 2009
                          • 679
                          have you checked ac power?
                          like actually checked if you have 220 going into the machine?
                          • Ragnarsson
                            • May 2009
                            • 35
                            Yes we have measured the 220v and that is OK
                            • Ragnarsson
                              • May 2009
                              • 35
                              - PROMBLEM SOLVED -
                              This was broken wire who caused all this.
                              Thanks all for your help
                              B
