Xerox 550 error 077-909.
  • IGEN93
    • Jul 2018
    • 49
    The copier , makes both simplex and Duplex copies in black and white mode , but gives error while copying or printing in color mode .
    If anyone have faced this issue and has any suggestion would be great.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox 550 error 077-909.
    What have you done to get this problem?
    NVM reset?
    Remove battery from NVM PWB?9
    • IGEN93
      • Jul 2018
      • 49
      NVM reset?
      Primarily there were multiple codes on machine , 124-338, 124-311, 116-320, 045-316, 10-320, 062-380/326, 077-909.
      I have cleared all errors and now stuck on 077-909,
      I have tried NVM reset, changed both the batteries (ESS and MCu),
      Replaced registration sensor , iot exit sensor, replaced fuser assembly, cleaned the drawer connectors .
      Still it gives code 077-909,i checked NVM chain link 742-003, shows 77108 or 77105(sometimes).
      • adriansto
        • 2388
        If the registration assembly was replaced, the OHP (transparency) sensor has been removed from the registration assemblies.
        If the registration assembly has not been replaced, the OHP (transparency) sensor may have failed or an IOT nvm initialization has been performed.
        • fugglefeet
          • Jun 2020
          • 34
          Hi IGEN93,
          Have a look at 2 possible locations for media stuck in the machine or defective sensors/connectors. Two Eureka Tips point to a jam in the MSI pre-registration sensor and a fuser exit sensor out of position.
          Hope this helps.
          fugglefeet
          • IGEN93
            • Jul 2018
            • 49
            Originally posted by fugglefeet
            Hi IGEN93,
            Hope this helps.
            fugglefeet
            i have already replaced fuser exit sensor, iot exit sensor, pre registration sensor.
            • xcopytech
              • Aug 2006
              • 1794
              Turn off OHP sensor in diagnostic.
              • fugglefeet
                • Jun 2020
                • 34
                Hi all,
                It looks like xcopytech is right. Thanks for nudging me in the right direction.
                The attached PDF confirms what is being experienced.
                fugglefeet
                • IGEN93
                  • Jul 2018
                  • 49
                  Hi all,
                  fugglefeet
                  Thanks for the solution, it worked , I found the missing nvm list from the machine and that nvm was listed in the list .
                  Thanks for the solution .
