Xerox WC 7830i blurry prints on PDF documents only
  • LATechnico
    • Jan 2017
    • 21
    Hi guys,
    Customer has a Xerox Workcentre 7830i printing blurry on PDF documents only. Happening from multiple computers but Word docs and emails print clearly. Using genuine toner and drums. Strange problem, any help is appreciated.
    Thanks!
    Re: Xerox WC 7830i blurry prints on PDF documents only
    Originally posted by LATechnico
    Hi guys,
    Thanks!
    how about posting examples ?
    • LATechnico
      • Jan 2017
      • 21
      Thanks Phil!
        Thanks Phil!
        have you run the adjustments in SM?
        what is the life on PM parts?
        any errors showing in error log?
        did you try switching any parts? if so what ones?
        we REALLY need better info given for us to help you.
        • jhalfhide
          • Apr 2015
          • 454
          As Phil said, much more info needed.
          Which driver are you using? Which pdf reader are you printing from? Have you tried the Adobe Reader 'Print as Image' option?
          Sent from my LYA-L09 using Tapatalk
            • 16455
            Low Original Resolution
            If you start with a low-resolution image or other file, the resulting PDF may look blurry or pixelated, especially if printed out. PDF converters can't make your finished document look any clearer than the original. Use files with resolutions of at least 72 dots per inch for Web display and 200 to 300 dpi for printing. Enlarging small images can also increase blurriness.
            Incorrect Settings
            Even if you start with good quality images and text, the final PDF file may look blurry. If this happens, check your output settings. Some PDF converters default to a relatively low resolution for output, resulting in a fuzzy-looking result. Use the same resolutions you would for originals, and don't choose images made at screen resolution for a document you intend to print. The file may look good on your monitor but will always do poorly on the page.
            Software Incompatibility
            Sometimes, you need third-party software to convert your file to PDF. For instance, Microsoft Word doesn't include native PDF conversion. Visio objects and some graphics embedded in Word documents may not combine well with third-party PDF converters, producing blurry charts and illustrations. Try converting the problem object into a format the third-party software can handle, such as a JPG, or use a different conversion program to produce clean results.
            • LATechnico
              • Jan 2017
              • 21
              Thanks for the fast response guys! The client is mostly working remotely now so took a couple weeks to get back to work on this issue. I brought in an experienced Xerox tech to help me out, he did the firmware update and that solved the problem so far. Thanks again!
