Xerox 4112 error 071-105 registration sensor on jam (tray 1)
  • IGEN93
    • Jul 2018
    • 49
    [Jamming] Xerox 4112 error 071-105 registration sensor on jam (tray 1)
    I have been facing this problem immitantly , machine was working good , but after power up next day , machine xerox 4112 has started giving error of 071-105 for tray 1, 072-105 for tray 2, and 073-105 for tray 3, paper stops exactly in the registration assembly, does not pass any further.
    Any support appriciated.
  • adriansto
    • 2384
    Re: Xerox 4112 error 071-105 registration sensor on jam (tray 1)
    Why you dont buy service manual for the machine ?
    Broken gear on pre-registration motor or check for broken gears or worn out drive components or paper guide with problems.
    • IGEN93
      • Jul 2018
      • 49
      I have service manual , followed it but didn't got any solution . Checked every gear, motor and sensors .all are good , have cleaned the clutch with petrol , but still same result .
      • CopierTechofOmens
        Agitating Artificer
        • 268
        Check the Registration upper chute for paper cuts, catching the paper. Also the wiring harness to the reg sensor can break due to tension and opening 2B.
        sigpic
        • IGEN93
          • Jul 2018
          • 49
          i have checked both the drawer connector and wirring harness with cable tester , all seems to be good.
          i hope there may be any nvm to override any sensor .
          • adriansto
            • 2384
            Post photos with the exact position of paper stop.
