Xerox C60 (need help to config Scan to PC/Folder)
  • xXFlipPTXx
    • Mar 2021
    • 33
    Hi,
    could someone help me how to configure my Xerox C60 to scan to pc (folder) ? It's been so long that I have been trying so many times to follow some tutorials on youtube but i always get stuck the part when is needed to create a template /address book because it have different options when i get inside the link server machine.
    I could send screenshots step by step to see how i must do because i started working with the xerox machine only by a year, you may tell i'm a noob on this. I want to learn and avoid to scan to usb, since i can't use the Remote Scan or fiery templates...
    Thanks,
    Flip
  • xXFlipPTXx
    • Mar 2021
    • 33
    Re: Xerox C60 (need help to config Scan to PC/Folder)
    Help? Someone?
    • tjvincent
      • 280
      I would suggest you search on YouTube there is plenty of videos on this subject
      • xXFlipPTXx
        • Mar 2021
        • 33
        • masio
          • Mar 2021
          • 19
          Help? Someone?
          For scan to PC/Folder means you are not using machine server. so you just acess it from UI menu (Scan to PC).
          step are :
          *NOTE : Use windows 7 !!
          1. Make share folder on your PC (name it whatever you want)
          2. On UI open Scan to PC menu
          3. change ftp to SMB, then browse...
          4. choose workgroup, find the share folder you ve just created
          5. Sett output file (PDF, JPEG,etc)
          6. Sett output colour
          7.Start....
          Thats all
          • xXFlipPTXx
            • Mar 2021
            • 33
            Thanks masio, i will report as soon as possible after following your steps.
            Greetings,
            Flip
