Xerox 7845 code on the back (on SBC) - 0
  • buzzgrafix
    • Mar 2021
    • 10
    [Error Code] Xerox 7845 code on the back (on SBC) - 0
    The device was stuck on the green screen saying it is powering on. I did the altboot and successfully reloaded the firmware.
    However, after the first reboot it came up to black screen with all lights ON.
    The only code I see is the one on the back - red number 0.
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox 7845 code on the back (on SBC) - 0
    Replace SD card
    • buzzgrafix
      • Mar 2021
      • 10
      Originally posted by xcopytech
      Replace SD card
      Can i use any SD card of the same size and do another ALTBOOT to rewrite it?
      Or it needs to be pre-programmed card?
      • buzzgrafix
        • Mar 2021
        • 10
        Replace SD card
        Nevermind, found an image for SD in another thread.
        Thank you!
        • buzzgrafix
          • Mar 2021
          • 10
          Replace SD card
          Just wanted to let you know that your advice worked. Got a new SD card, re-imaged it. And then did Altboot again and it is working.
          Thank you so much!
