xerox
  • rxpluday
    • Jun 2017
    • 6
    xerox
    Hi
    5955 PWS_AltbootTool software required
    pls upload the link
  • jhalfhide
    • Apr 2015
    • 454
    Re: xerox
    You altboot with a usb using the freely available firmware on xerox.com
    Details on USB file/folder structure are on your service manual under general procedures.
    Sent from my LYA-L09 using Tapatalk
    • JR2ALTA
      • Feb 2010
      • 2033
      Re: xerox
      don't some xerox require USB a-to-b cable and software?
      • jhalfhide
        • Apr 2015
        • 454
        Re: xerox
        Some do, but not this one. The USB cable method tends to be on their production kit and not the office Workcentre/AltaLink/VersaLinm range
        • Murv
          Sr. Escalations Analyst
          • Mar 2021
          • 182
          Re: xerox
          Older machines and production, yes. And, there's the PuTTY tool, as well, but that's a different story. But, on this one a simple altboot directory on a USB that contains the .dlm and an empty text file (with no extension) named FORCED_UPGRADE will do the trick. If you want to wipe it out during the alboot, also include a similar file named DISABLE_DATA_BACKUP in the altboot directory as well. Depending on how far up the FW ladder you are going, it might just wipe it anyway. Be aware, an altboot takes a while.
          MRS
