Xerox 7855 error code 303.355
  • issambass
    • Dec 2019
    • 29
    [Error Code] Xerox 7855 error code 303.355
    hello ,
    i have a Xerox 7855 error code 303.355
    in the SM :
    Power On Self-Test failure detected during the NVM Integrity Test; NVM battery dead
    Procedure:
    The SBC NVM battery may be loose, failing, or has failed. Reseat the SBC NVM PWB battery. If the problem continues, go to REP 1.11 to replace the SBC NVM PWB.
    can i change NVM battery dead ?
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: Xerox 7855 error code 303.355
    Mine says: 303-355 Power On Self-Test failure detected during the NVM Integrity Test.
    Which only happens if multiple failures of HDD and SD card happen and the backups are lost
    sigpic
