Xerox C5005D Service Mode
  • Pfhantom
    • Mar 2021
    • 1
    Hello,
    how do you access the service mode in Xerox c5005d?
    This is from the service manual :
    Code:
    6.4.1.2 How to Enter the CE Mode
    As the UI Panel is equipped, the operating procedure will be explained here.
    1. How to Enter the CE Mode
    (1) Press and hold the <Right> key then press the <Left> key, too.
    (2) After release the their Key, press the <Online> Button with in 3 seconds. The "Diag" screen will
    be displaied.
    Tried it with the control panel attached to the printer, doesn't work.
    Tried to search for the "UI Panel" mentioned, no luck, and no one seems to know what it is.
    Any help is very appreciated.
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Re: Xerox C5005D Service Mode
    "UI" means User Interface. It's the same thing as the control panel. Hold the right arrow and left arrow for 5-10 seconds before releasing.
