Problem with Xerox DC252
  • eng_usama
    • 115
    hello guys we use this machine in printing radiology there is problem with it there is thin white line appear on images i try many solution nothing slove the problem hope you can help me thanks in advance i attach photos to show the problem
  • nikolai.aleksie
    • Feb 2016
    • 177
    Re: Problem with Xerox DC252
    What you already tried?
    Feed direction?
    • eng_usama
      • 115
      I tried and Change the following transfer belt unit change 4 drums unit and also dev tanks also fuser unit no luck
      • nikolai.aleksie
        • Feb 2016
        • 177
        Clean the ROS Windows
        • eng_usama
          • 115
          What is ros window and by the way this line on sra3 is horizontal not vertical
          • IGEN93
            • Jul 2018
            • 49
            you need to blow the developer assembly clean it and then check for any thin marking on the magnetic roller , also rinse the developer with thin mesh to clean all the particals, if the problem is not sorted check the ROS windows.
            if it is printed in 4 color mode then check all the colors , if printed in black and white mode then check only R1 Xerographic system.
            • zagrex
              • Dec 2011
              • 63
              Hi
              check your 2nd BTR assy / paper path
