Xerox C75 094-322
  • cpress
    • 37
    Xerox C75 094-322
    Keeps throwing this code,There was a new 2nd BTR installed a couple weeks ago. It does make a small grinding sound when starting up. The gears on the bar unit look good. Drive motor gears bad possibly? Whats the best way to get to the drive gear?
    These are the steps the manual says to take.
    • The 2nd BTR Nip/Release Sensor (DC330 [094-201]) for operation failure. (PL 6.8)
      • The 2nd BTR Retract Cam Clutch (DC330 [094-003/004] (Contact/Retract)) for operation failure.
      (PL 3.4
      NOTE: Before performing DC330 [094-003/004], activate the Main Motor (DC330 [042-001]) first.
      The Main Motor (DC330 [042-001]) for operation failure. (PL 3.4)
      The Deve Clutch K (DC330 [093-023]) for operation failure. (PL 3.4)
      NOTE: Lower the IBT Unit before performing DC330 [093-023].
      The Drive Gear for wear and damage.
