XEROX B8045
  • TOTO
    • Sep 2019
    • 21
    XEROX B8045
  • Exok
    • Jun 2011
    • 750
    Re: XEROX B8045
    The best way to troubleshoot this is by observing the POST (power on self test) code. Find out what the code it at the point of rebooting itself.
    • TOTO
      • Sep 2019
      • 21
      Re: XEROX B8045
      thanks for your answer but the machine does not record any code
      another suggestion thanks
        Re: XEROX B8045
        not a code but a progress counter.
        ex: 25% 50% 75% also watch the lights on the emod
        • xcopytech
          • Aug 2006
          • 1792
          Re: XEROX B8045
          POST code!!!
          There is small led display on SBC pwb.
          Post here what code you have on that display
          • T911
            • Jun 2007
            • 628
            Re: XEROX B8045
            I have a b8045 with the same problem listed above. My code on the LED Display is 5. Help Appreciated. Thanks
            • xcopytech
              • Aug 2006
              • 1792
              Re: XEROX B8045
              Replace sd card
              • T911
                • Jun 2007
                • 628
                Re: XEROX B8045
                anything stored on the sd or just put in a blank one, fw reinstall? Does it need to be formatted before install? X not my cup of tee. Kyo guy
                • Murv
                  Sr. Escalations Analyst
                  • Mar 2021
                  • 182
                  Re: XEROX B8045
                  Re-image the SD card.
                  • T911
                    • Jun 2007
                    • 628
                    Re: XEROX B8045
                    Murv,
                    I don't have another b8045 to re-image the 4gb sdhc with. do you have one that you can share with me. thanks
                    • Murv
                      • Mar 2021
                      • 182
                      Re: XEROX B8045
                      Originally posted by T911
                      Murv,
                      Not something I can legally share.
                      The IMG file can be obtained from GSN. Unfortunately, if you do not have a GSN account I'm not sure how you would get the image.
                      Sorry.
                      • T911
                        • Jun 2007
                        • 628
                        Re: XEROX B8045
                        Originally posted by Murv
                        Not something I can legally share.The IMG file can be obtained from GSN. Unfortunately, if you do not have a GSN account I'm not sure how you would get the image.Sorry.
                        Okay thanks anyway
                        • Sandy Marino
                          • Dec 2021
                          • 18
                          Re: XEROX B8045
                          Tray software again but do a Forced Altboot this time, if that fails, do one more altboot forced upgrade with disable data backup, if that fails replace the hard drive and do just a forced altboot, it should like a machine new out of the box and you will have to reconfigure network settings etc good luck
