Xerox C60 copy quality issues
  • mshabban
    • Jan 2017
    • 101
  • jhalfhide
    • Apr 2015
    • 454
    Re: Xerox C60 copy quality issues
    You don't seem to have said what the actual quality issue is. Can you post an example? Have you tried test pages from service mode?
    Sent from my LYA-L09 using Tapatalk
    • mshabban
      • Jan 2017
      • 101
        what gsm of the paper?
        what is the PC calling for as far as the weight?
        what is the copier think it is printing to?
        are they using genuine OEM toner/drums
        post examples in PDF format
        • mshabban
          • Jan 2017
          • 101
            so when you pull the toners does it say XEROX GENUINE ?
            print the Config page and post it... the machine will display what paper setting is for each tray Type .. size ..weight
            when you turn the machine on does it print a settings page at startup?
            can you use the IP address to login to the machine?
            • mshabban
              • Jan 2017
              • 101
              • JR2ALTA
                • Feb 2010
                • 2033
                You can't run Xerox production machines using default paper settings. You need to go into admin mode and create your own paper catalogue. You need to print out a transfer adjustment chart (SIQA) and select the row of colors will the best fill. This is the only way to avoid mottle and density issues.
                This video should be the same as a C60 or close enough.
                Xerox Versant 180 Simple Image Quality Adjustment / SIQA Image Transfer - YouTube
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  It's all about the paper on these.
                    Xerox has always ( as far as I know ) a very narrow media requirements.
                    • Murv
                      Sr. Escalations Analyst
                      • Mar 2021
                      • 182
                      I hate to be THAT guy, but I'm going to be THAT guy - Samples or it didn't happen.
                      • Sn0wlink
                        On-Site Engineer
                        • 35
                        As said previously, samples are needed to make a good diagnosis. However my first guess is to setup a custom paper profile as it sounds like a toner transfer problem.
                        There's the tool the works, Then there's the tool that is Right!
                        https://www.sn0wlink.com
