Xerox 8570 Recover Firmware
  • AlexRust
    • Apr 2014
    • 41
    Please help - after upgrading firmware on Xerox 8570 printer rebooted and nothing on the screen and red light flashes. Can it be fixed?
    • 22808
    Re: Xerox 8570 Recover Firmware
    are you sure you uploaded the proper firmware? correct region?
    how did you do the firmware upgrade via ALTBOOT?
    • AlexRust
      • Apr 2014
      • 41
      Firmware downloaded from Xerox website:
      I have tried via network it was loading till 46% and then reboot and still old firmware (I probably should stop at that point), then I connect USB and uploaded via Windows Xerox File Downloader Utility, this time is went all the way, I even saw message writing to nvram, after that it rebooted with red light flashing and nothing on the screen. Can you help?
        • 22808
        ColorQube 8570 / 8870 Firmware Release - SER72 - ColorQube 8570 - Xerox
        Try usb ALTBOOT
        • AlexRust
          • Apr 2014
          • 41
          Can you provide instruction on how to load firmware via ALTBOOT? Should I try to load same firmware?
            • 22808
            1) are you a tech? IF NO hire a tech or someone here might be willing to help
            2) google the instrutions
            3) altboot is special firmware should be on xerox website
            the link you provided is not recovery firmware.
            • AlexRust
              • Apr 2014
              • 41
              I am Kyocera tech, I inherited this beast and need help. I am happy to hire tech but cannot find any locally.
              Can I hire you?
              The link I provided is for firmware I was trying to install. I know I need .dlm file to recover and link to .dlm file possibly this one:
              "Edit" link above is not correct "End of Edit"
              Do you know anybody who can help if you are not available?
              • AlexRust
                • Apr 2014
                • 41
                Is Anybody here can help me with this? I cannot find on Xerox website anything about altboot option for 8570...
                • Murv
                  Sr. Escalations Analyst
                  • Mar 2021
                  • 180
                  Assuming you are talking about a ColorQube 8570 you've got three ways to load the firmware:
                  The FW Downloader Tool <-- best bet (Xerox File Downloader Utility - Phaser 8500/8550 - Xerox)
                  Via CWIS (the embedded web page on the machine)
                  FTP session and PUT
                  • Murv
                    • Mar 2021
                    • 180
                    CQ8570_8870_SER72_Release_Notes_4.72.0.pdf
