Xerox WC7120 with Fault Code 117-325
  • fadsamniote
    • Apr 2016
    • 80
    Hello !
    Im having Fault Code 117-325 after turning On the machine (The machine didnt had Battery on the Board).
    I cant find SERVICE MANUAL for WC7120/7125 only WC7220/7225 (They arent the same has you know).
    Any help here please ?
    Best Regards
    Re: Xerox WC7120 with Fault Code 117-325
    Originally posted by fadsamniote
    Hello !
    Best Regards
    per forum rules: Service Manual Requests - All requests for service manuals must be made in the Service Manual Request Forum. Please read the special rules sticky in that forum for posting guidelines. service manual requests made elsewhere on the site WILL BE DELETED.
    https://www.copytechnet.com/forums/s...nual-requests/
    I'm not sure if you machine requires a PWS for the manual to open.
    Are you a tech? I cannot confirm that looking at your profile.
    you might want to review the forum rules: https://www.copytechnet.com/forums/misc.php?do=vsarules
    • fadsamniote
      • Apr 2016
      • 80
      Im tech yes ...
      I didnt asked for SM , I just said that I cant find any info because I only have the Manual for 7220 , the machines use same parts but they are different offcourse ...
        Im tech yes ...
        re-read your original post.. usually when someone states they can't find a Service Manual and then asks for help THAT indicates to me they are looking for the service manual!
        Originally Posted by fadsamniote
        Hello !
        Best Regards
        re: your profile.
        it would make it easier for all involved if you fill in your profile that way there will be no question about your qualifications.
        and the amount of RED CARDS you have collected doesn't say much for your willingness to lend help and you only come here when you NEED something for free.
        but I digress I won't try and lend a hand to ever again.
        • fadsamniote
          • Apr 2016
          • 80
          My friend ... If you have any info about Fault Code 117-325 just let me know !
          Thanks ...
          Hello !
          Best Regards
          re: your profile.
            My friend ...
            don't call me your friend .... you have not won me over to your side... not one bit mooch
              • 37522
              Based on the publication dates on the manuals available from Xerox, the WC7120 is over ten years old. Time to dump the boat anchor and get something new.
              • adriansto
                • 2388
                Hello !
                Best Regards
                Not 117-325 code in service manual.
                Are you sure this is the code but 116-325 ?
                • fadsamniote
                  • Apr 2016
                  • 80
                  Hello !
                  yes , Im sure ...
                  • xcopytech
                    • Aug 2006
                    • 1794
                    Replace ESS pwb
