Phaser 7800 Fault
  • rrutter81
    • May 2018
    • 28
    [Error Code] Phaser 7800 Fault
    Hey guys,
    Looks like my phaser is giving me another issue and you all have been my go-to over the years. Tray 4 on my phaser is giving me problems and wont allow me to print unless I leave it part-way open. The fault code on the actual display is 374.940.04 but on the server of the device it is 74-210-00. I'm guessing a lift motor on tray 4 is dead, but i do hear motors run when I close the tray. So maybe it is a gear?
    I found this package to replace it, but not sure without opening it up.
    604K20542 replaces 604K20541, 604K20540, Tray Lift Gear Kit (OEM) Xerox(R) 7500 & 7800
    Are there any procedures i can follow to replace or diagnose what is the actual issue? I've already replaced numerous things on the phaser over the years like the imaging unit and what-not but I havent ever messed with the tray assembly.
    Any assistance would be greatly appreciated!
    -russ
    Re: Phaser 7800 Fault
    Originally posted by rrutter81
    Hey guys,
    -russ
    is there any paper stuck at the tray sensors?
    have you checked the feed tires?
    • rrutter81
      • May 2018
      • 28
      Hey Phil,
      Thanks for the reply.
      I dont see anything amiss when i pull the tray out.
      • rrutter81
        • May 2018
        • 28
        For fun, I replaced tray 4 with tray 5 and the error follows the tray itself. So placing tray 4 in to the tray 5 slot gave me a tray 5 error.
        • rrutter81
          • May 2018
          • 28
          Ok i found the culprit. One of the plastic gears broke off in back for whatever reason.
          /sigh
          this printer loves to break a lot ๏ฟฝ๏ฟฝ
          • Jettdog
            • May 2021
            • 48
            Hey Phil,
            Isn't tray 4 the same as tray 3? swap trays 3 and 4. I bet the problem follows the tray. The lift gear assy on the the side of the tray is messed up. Either broken or just out of place. Should be easy to replace if needed.
            • rrutter81
              • May 2018
              • 28
              Yeah. I ended up doing what you suggested and found one of the gears was broken. Thanks!
              • jhalfhide
                • Apr 2015
                • 451
                The new gears now come with a metal backing to them to stop them breaking.
                Part number 604K20543
                Sent from my LYA-L09 using Tapatalk
