Xerox ApeoSport VI C3371 error
  • Alex1
    • Oct 2012
    • 285
    I have a Xerox ApeoSport VI C3371 with the following errors CMYK Toners missing or not fully inserted and R1 Drum Cartridge missing or not fully inserted. I have replaced the R1 Drum Cartridge with R2 same error comes up. Any help will be appreciated.
  • shinchan
    • May 2011
    • 197
    Re: Xerox ApeoSport VI C3371 error
    check the toner chip / cartridge number
    that machine have different region:
    1. metered chip
    2. asiapacific region chip
    3. China region chip
    4. Japan region chip
    • Alex1
      • Oct 2012
      • 285
      1. metered chip
      They are the correct chip. The machine was working fine with the exact same consumables in it, then all of a sudden after relocating it this comes up.
        key words: then all of a sudden after relocating it this comes up.
        go check the CRUMS for all supplies... check door switches
        • Alex1
          • Oct 2012
          • 285
          I have already done that. Checked chips and door switches all look good. I just tried those consumables in another machine tested all toners and R1 Drum they work fine in another machine.
            so then it could be crum readers..pull check for fubar'd connection.
            • Alex1
              • Oct 2012
              • 285
              I'm suspecting the Motor Drive PWB which also controls the drums and toner. I might replace that first.
                does mtr dr pwb run the crums? i've had them go out on many models.
                • Alex1
                  • Oct 2012
                  • 285
                  Yes it does. As shows in te service books.
