How to increase fusing temperature in altalink C8045
  • hnami
    service technician
    • Nov 2023
    • 169
    Hello, friends, does anyone know how to make the fusing temperature higher than normal? Is there a place to change the values ?in the NVRAM program?
  • xcopytech
    • Aug 2006
    • 1794
    Why you need to increase fuser temperature?
    • hnami
      service technician
      • Nov 2023
      • 169
      On thick paper, the color rises from the work surface
      • adriansto
        • 2387
        Too much toner on paper, no fuser culprit. Tone up/down procedure.
        • hnami
          service technician
          • Nov 2023
          • 169
          But in normal paper is good
          • ATB
            • Jan 2019
            • 79
            normal paper is not thick paper. Thick paper is... thicker. Not very scientific or necessarily relevant but that may help understand : if you have a 2cm space between 2 rolls and you try to make a 1,5cm pizza with 0,3cm of topping go through them, they'll pass. if you add 0,3cm of tomato sauce on top of it, the 0,1cm of exceeding tomato sauce on top of it will spill all over the place : too much tomato sauce (or too thick pizza)
            • hnami
              service technician
              • Nov 2023
              • 169
