Xerox WorkCentre 7830 All lights ON & LCD blank
  • Itsahmad88
    • Jul 2021
    • 4
    Hi there,
    all the lights on panel are on and got black screen, i tried to upgrade software, format hard-disk & then i have tried to re-install firmware.
    all of the above solutions failed, I have attached the images for error is there anyon
    e who can help me to troubleshoot the problem or i need to bring the machine to the service centre.
  • yDaff
    • Feb 2021
    • 5
    Re: Xerox WorkCentre 7830 All lights ON & LCD blank
    SM -
    Initial entry to kernel - 0 Flashing - Waiting for Power Normal
    1.Reload system software.
    2.If problem persists, reseat SD Card.
    3.If problem still persists, replace the SD Card.
    4.If problem still persists, replace the SBC.
    After successful memory test the display is set to 0 and remains 0 if autoboot is interrupted by user. If there is no user interrupt 0 remains until the Power Normal signal is raised (after POST has completed (~25s). If Power Normal is not raised or u-boot does not hand over to kernel then 0 will also remain displayed.
    From experience - SBC battery voltage dropped below 2.7V. Replace battery and overwrite software. IMHO
    • Itsahmad88
      • Jul 2021
      • 4
      Originally posted by yDaff
      SM -
      Thanks for sharing your experience.
      are you talking about battery shown in image above? please confirm.
      THan
      • Itsahmad88
        • Jul 2021
        • 4
        SM -
        are you talking the battery shown in the image above?
        • yDaff
          • Feb 2021
          • 5
          yep
          • mntech
            • Aug 2010
            • 250
            I've seen this a couple time
            Once I had to replace the network controller board
            Another time was the power supply board behind the right side cover
            -mntech
            • Itsahmad88
              • Jul 2021
              • 4
              Hi,
              Thanks for everyone for recomended troublshooting.
              I successfully solve the previous error & now the Machine have another problem which I have showed in the video recording below:
              I have tried the following solutions:
              1: Tried AltBoot (tried 3 type of old Flash Drive)
              2: Formated HDD (also tried with another HDD by formating FAT32)
              is there any other way to solve the issue?
              • Murv
                Sr. Escalations Analyst
                • Mar 2021
                • 180
                Originally posted by Itsahmad88
                Hi,
                Re-image the SD card. If you don't have the image and utility, get a new SD card from Xerox.
                • rosaro75
                  • Mar 2009
                  • 86
                  Hi,
                  this is problem due to hard disk. format hdd. try to do altboot.
                  • Kjmax87
                    • Dec 2023
                    • 2
                    Main board segment Displays number 2 and machine stuck anyone can help me to fix this error
                    • xcopytech
                      • Aug 2006
                      • 1747
                      Check or replace memory
