Xerox 700 041-346
  • Samxerox
    • Apr 2023
    • 44
    Xerox 700 041-346
    Can anyone help.
    The machine has locked down with this code 041-316
    Due to the form being moved all links to old threads are dead and old information is lost at the moment.
    I have taken out the belt unit and cleaned it and cant see anything obvesious and the 2nd btr.
    Any advice would be good or the nvm code I need to reset just incase its a hard reset that needed.
  • adriansto
    • 2392
    Originally posted by Samxerox
    Can anyone help.
    Blown F3 fuse on IOT PWB
    • Samxerox
      • Apr 2023
      • 44
      Does that mean its a fuse on the board thats gone.
      • xcopytech
        • Aug 2006
        • 1794
        Check front door interlock
        • Samxerox
          • Apr 2023
          • 44
          took out the switched and looked at it and its in prefect shape.
          Rebooted the machine and it gave me the error 041-345 communication error.
          Rebooted and now its 010-319 heat sensor error even with the duplex tray and fuser removed.
          After resetting 010-319 im now getting that problem I think i started with 094-321 1st btr issue.
          Could there be an issue in the belt assembly
          im really at a loss on what to do to fix it as all google links to the form are dead so a lot of useful information are gone and as I search the form its finding nothing of use.
          I may just have to junk the machine.
          • xcopytech
            • Aug 2006
            • 1794
            Try new interlock switch or shortplug it.
            Interlock make 24V issue
            • Samxerox
              • Apr 2023
              • 44
              defently not the switch
              • adriansto
                • 2392
                Check fuse on iot. If it isblown something on machine broke 24 volts. If it is not blown then missing 24 volts on some machine parts. A lot of measurements most done. Pay a tech to do that. You dont want to broke your printer.
                • xcopytech
                  • Aug 2006
                  • 1794
                  Then check fuses on iot pwb
