Xerox 800/1000 press
  • Christchurch Printers
    • Jun 2024
    • 6
    Hi everyone
    I have picked up a used xerox color 800 press, which I have been assembling for use.
    I am confused about the waste toner auger connection between IOT and fuser sections - is there meant to be a connection pipe? or does something slide out that I am missing?
    Would appreciate any tips on that issue, and any directions to assembly or service manuals that might be available.
    Cheers
    Jim
  • Milo Wilson
    • 502
    Yes on the left side IOT, rear on the left side. Remove the upper rear panel then open the left outer pwb mount and behind that the slide connection for the waste auger is located.
      • Jun 2024
      • 6
      Thanks so much Milo. I had not looked behind PWB to find the little screw to release it! All is well now. Cheers
