xerox c8045 printout problem
  • ps3123
    • Jun 2024
    • 4
    this is output from xerox c8045 printer
    paper 100lb 12X18
    pic attach in rectangle box there are background gray image on bottom almost 1.5 inch band 18 inch long
    rectangle box in middle also have background image 18in long
    any advice and recommand are welcome thanks
    scanp2.pdf
  • ps3123
    • Jun 2024
    • 4
    same pic reduce size
    • ps3123
      • Jun 2024
      • 4
      print about 800pages 12X18 100Lb card stock ,one side ,then problem arise see scanp22.jpg
      developer replace ,black,magenta cyan and yellow developer replace itb belt blade replace and cleanied
      drum blade ordered in process
      • shinchan
        • May 2011
        • 194
        take a look at the dev housing. sometimes the inner seal is broken. causing toner flying to drum... the bottom seal broken, then toner drops to LPH.
