Xerox 700 CW and error 10 question
  • Apach
    • 157
    [Misc] Xerox 700 CW and error 10 question
    Hello,
    1. Can anyone tell me which version of Command Workstation can be installed on the Fiery EX700 ?
    2. When I try to run the Fiery update, I see everything that needs to be installed. However when I run the "download and install" I get fail report with message error 10
    Any advice? Thanks
    There is no stupid question, just stupid answer
  • irdicheku
    • Aug 2019
    • 17
    Re: Xerox 700 CW and error 10 question
    Originally posted by Apach
    Hello,
    Any advice? Thanks
    Try to look for Command Workstation Version 5.8
    • Apach
      • 157
      Tnx. 5.8 working good.
      Fiery update: I entered all the updates manually almost 2h . After the last entry I got a message that I need another file to autoupdate There is no way I can do that.
      • kado
        • Apr 2019
        • 18
        Sounds that your EX700 is XP, use CWS 5.2 or 5.3. if your EX700 come with Win7, you can choose CWS 5.8 then.
        Regards
