Fault code 045-368 on dcvi c3371
  • pengtech
    • 41
    [Error Code] Fault code 045-368 on dcvi c3371
    hi all,
    i am facing an error code 045-368 on the dcvic 3371, the machine was unable to fax in/out before the error code appeared. i have no idea what's went wrong.
    hope you guys can give some advises on this issue. thanks
    i have unpluged the connectors on the fax unit but same error appeared.
  • shinchan
    • May 2011
    • 197
    Re: Fault code 045-368 on dcvi c3371
    Hope this helps
    • pengtech
      • 41
      thanks shinchan, i managed to get the machine running after reconnected the connectors of the mcu. thanks once again
