Hi everyone.
I have 5 altalinks under my care that had hdd's completely destroyed/erased so after starting they were asking for password. i realized that this problem exist because there is no OS on hard disk so i sourced files for special-recovery altboot and run it. machines are all up and running but theres a problem that im unable to solve. all machines are showing a notification in the upper bar "Scanner Calibration Error, Image quality may be degraded" i checked the fault history, there were few problems but i solved them by applying LDRCP patch however error 319-350-00 "Missing Calibration File At Reboot" still appears. i did all 3 calibrations from admin level, pluged, unpluged, started restarted countless times and i don't know what else can i do. these machines are a pretty low counter examples but in this state are not sellable. can you help me with this?
everything works great, machines are scanning copying all without any problems but this message ""Scanner Calibration Error, Image quality may be degraded"" appears all the time.
