J75 error code 061-340
  • Reeves
    • Apr 2012
    • 296
    [Error Code] J75 error code 061-340
    Hi Techs
    I have a xerox J75 machine error code 061-319 when I got the error code after checking it was talking about black ROS but I changed the black drum and it started working okey the following day I got the same error code 016-319 the error just started on its own what could be causing this? MCU , ROS or flat cables
  • xcopytech
    • Aug 2006
    • 1794
    So do you have 061-340 or 061-319
    • Reeves
      • Apr 2012
      • 296
      061-319
      • adriansto
        • 2387
        Originally posted by Reeves
        061-319
        Check again black drum and if it is ok go and follow the RAP for 61-319 from service manual
        • Reeves
          • Apr 2012
          • 296
          I got a black drum from another machine it is working but after sometime it brings the same error code 061-319 but the old drum it is bringing the error just when I switch the machine on
          • xcopytech
            • Aug 2006
            • 1794
            Did you check front door interlock
