fault 094-322 xerox 242
  • creative-proto
    • Oct 2019
    • 4
    getting this fault when attempting to print or when warmings up. So frustrated! please help
  • adriansto
    • 2329
    Re: fault 094-322 xerox 242
    The 2nd BTR retract fault. You must read the procedures from service manual. Multiple causes.
    • Dech
      • Aug 2014
      • 48
      Remove the whole btr -duplex draw. the two plugs at the back of the draw, that push into the plugs on the machine frame. the bottom one has been damaged, replace the plug..... Make sure there is no paper stuck in the plug on the frame side....
