Xerox V80 error 049-239
  • Samxerox
    • Apr 2023
    • 44
    Hi
    Have a xerox V80 And the high capacity tray is stuck at the bottom and the machine has this error.
    049-239
    Casn anyone tell me which sensor this is refering to cant find information on it any where
  • xcopytech
    • Aug 2006
    • 1794
    Front tamper home sensor (diag check code 049-226),
    Front tamper motor (check code 049-012)
    • Samxerox
      • Apr 2023
      • 44
      Thank you thank you thank you.
      The front jogger / Tamper had broken.
      The plastic clip the belt is held by that moves it in and out had broken off the unit.
      Ive super glued it back on and done a bit of plastic welding on it.
      So its up and running again.
      So once again thank you for your help.
