Xerox 7855 (and others) rotate all pdfs by 270 degrees.
  • szanka
    • Dec 2011
    • 29
    Soft is 75.040.010.12010
    The problem is that the files are rotated by default to 270 degrees. When opening such a file in adobe reader or foxit - there is no problem because the program itself rotates the original.
    The problem arises when the erp software which the client is testing tries to process the document. Then it reads the embedded rotation information and treats the file as such. The originals appear twisted in the system.
    We need to find out if this is a Xerox issue or if it is possible to set the rotation to 0 degrees. E.g. when I create a document in Word, save it as PDF and preview it in pdfino it is 0 degrees.
    The only working combination is scanning the document "horizontally" with the original orientation vertical where the encoded information is still 270 degrees but if you put the document this way it rotates to the correct orientation
    Below I paste an extract of the encoded information from the file.
    I use xpdfreader with the command line from the link to preview the encoded information Download Xpdf and XpdfReader
    C:\Users\marcin\Downloads\xpdf-tools-win-4.03\bin64>pdfinfo C:\Users\marcin\Desktop\exatel\testy\aa\3.pdf
    Creator: Xerox WorkCentre 7855
    Producer: Xerox WorkCentre 7855
    CreationDate: Wed Aug 4 10:49:48 2021
    Form: none
    Pages: 2
    Encrypted: no
    Page size: 842 x 596 pts (A4) (rotated 270 degrees)
    File size: 162139 bytes
    Optimized: no
    PDF version: 1.4
