Altalink c8045
  • Hassann
    • Jul 2023
    • 75
    Altalink c8045
    Hello
    i have a problem in xerox altalink c8045 keep restarting and gives massage (a non-recoverable fault has been detected. the device cannot boot)
    I tried to fix it with software but same problem after software completed
    Any advice pls
    Thanks advanced
  • adriansto
    • 2383
    Originally posted by Hassann
    Hello
    Any advice pls
    Thanks advanced
    Ussualy the SD card dead or corrupt software on it. You need new sd card with software on it.
    • Hassann
      • Jul 2023
      • 75
      I swapped the control with another machine same problem in this one and another one worked without problem
      so I think sd and hdd are ok
      • adriansto
        • 2383
        Then look at the faults history in the working machine who have the SBC board from bad machine
        • Hassann
          • Jul 2023
          • 75
          Ok i will check it
          thanks a lot
