Paper feeds thru to exit all but the last inch so doesn't total eject the sheet most times, sometimes it does. In addition there is no image on the page completely blank. Tried cleaning, checking and testing the pickup roller, empty tray sensor, feed sensor, registration sensor, and exit sensor in service mode all check good. Doesn't matter if you print from main tray 1 or bypass tray. Makes no difference if you try to print to machine, make a copy or do an internal print of the demo page, same issues with the jam condition and blank image on the page. Any suggestions, if anyone has ever experienced this before on this Xerox Workcentre 3345.?
Xerox Workcentre 3345 7-130 jams & blank copies
