xerox versant 180 error code 42-384
  • Ogin87
    • Aug 2024
    • 17
    hi
    i get error code 42-384 in xerox versant 180
    i changed the following
    ITB
    ITB cleaner
    drums
    2nd bias
    i cleaned the encoder and IBT sensor
    I tried to change NVM 741-852 0 to 1
    still the same problem
  • xcopytech
    • Aug 2006
    • 1783
    Do you have service manual? Do you know what for is this error?
    • Ogin87
      • Aug 2024
      • 17
      I dont have service manual
      • xcopytech
        • Aug 2006
        • 1783
        First try to find service manual before start to fix machine.
        Check these nvms
        Versant 180 042-384.pdf
        • Ogin87
          • Aug 2024
          • 17
          I already checked this page on NVMs
          when I applied them
          i get error code 42-320
          • adriansto
            • 2372
            when I applied them
            There are two bulletins which tell to change AC Power Supply pn 105K32222.
            Another bulletin say to check if BUR to flywheel coupler is damage- broken.
            The changes in nvm list is for machine IBT WITHOUT encoder. You say you clean the encoder so these modifications isnt for you.
            • Ogin87
              • Aug 2024
              • 17
              problem solved
              AC power supply (105K32222) changed
              thank you
              This gallery has 3 photos.
