Xerox D95a error code 077-109
  • bahamid
    • Feb 2012
    • 23
    IMG-8270.jpgHello everyone
    please can help for this error I took out all the papers but I have still error
  • xcopytech
    • Aug 2006
    • 1792
    Iot exit sensor
    • mkdirs
      • Oct 2014
      • 177
      BSD On
      BSD 10.10, BSD 10.1 Description
      In Non-Invert Mode, IOT Exit Sensor is not turned Off within a spec time. Initial Action
      • Paper Path for a foreign object/burr/piece of paper
      • Exit Roll for dirt/paper particles/wear/a poor rotation
      • Drive gears for wear/breakage
      • Invert Gate for an improper operation
      • Check for out-of-spec paper.
      • Go to OF-22 Chain-Link No. RAP to find last sensor actuated and the next sensor to be actuated in the Paper Path BSD 7.22, BSD 7.23, BSD 7.24, BSD 7.25.
      Procedure
      CC Code to Check
      • [077-108] IOT Exit Sensor ( PL 16.2)
      • [010-001] Fuser Drive Motor ( PL 10.2)
      • [077-010] Exit Motor ( PL 10.4)
      Check Items
      • Check the wire-wound resistance of Exit Motor is approx. 2.6 Ohms at the measurement points below.
      • Check the following for an open wire or poor contact:
      If the above wires are good, replace IOT Exit Sensor ( PL 16.2) and Flexible Print Cable ( PL 2.1) in order. If the checks are OK, replace IOT PWB ( PL 2.1) and MCU PWB ( PL 2.1) in order.
      Xerotk.com
      xerox copier technician
