Hi guys,
I have an issue and I don't figure it out!
My printer started and after 5 minutes or so I receive the 041-346 error.....
I have replaced the f3 fuse but is still blows..
I have tested all the fans with the f3 fuse blown and the only ones that didn't work where the ac cooling and the exit fans both, I have put them on 24v to see if they start and I see only a slight movement the rest of the fans are working.
I have changed the f3 fuse and without the exit fans and ac cooling I have started the machine and the fuse blown again.
I have tested the 1st BTR which seems to be fine you can measure 5 oms between pins, actuator is alright, I have 24v on IOT PWB coming from LVPS and I have 24v on LVPS also, all the motors from drums are working, pre registration is working, 2nd BTR motor is working... Main drive clutchs are around 190 oms, I did not find any short for the moment.. Dose anyone have any idea what it can be?
Thank you!
Thank you!
