Hello, dear professionals. We have a Xerox Versant 180 printing machine. After a long move, when turned on, it gives an error 044-370. An engineer came and said that the power supply unit needs to be replaced. They replaced it, but it didn't give any results. Tell me which way to dig. We live far from large cities. Therefore, we are figuring out the problem ourselves. Thanks for the answers!
xerox versant 180 044-370 error/ need help
Tags: None
As example :
Take away motor (PL 10.12 item 4) faulty taking out LVPS2 (PL 18.5 item 1) and PH PWB (PL 18.4 item 1).
Something burnout the LVPS 2. You must check if LVPS2 is still alive then found the component with problem. It is avery good ideea to have service manual.
As example :
Take away motor (PL 10.12 item 4) faulty taking out LVPS2 (PL 18.5 item 1) and PH PWB (PL 18.4 item 1).Comment
As example :
