Help with Xerox Colour 550
  • eng_usama
    • 115
    Hello guys problem with this machine there is black spots over the printed photo I replace dev tank drum change toner and no luck hope that you can help me thanks in advance 17278620080816017012906356576142.jpg 17278620080816017012906356576142.jpg
  • xcopytech
    • Aug 2006
    • 1747
    There is nvm changes for "oil spots" problem
    If that do not help then change black developer hvps
    Also check ibt belt for spots
    • eng_usama
      • 115
      Which nvm value you mean can you tell me please thanks
      • eng_usama
        • 115
        Can anyone please help me with this procedure to solve this issue?
        • raomassaro
          • Dec 2022
          • 9
          When I had these spots, the problem were always bad toners
          So I replace the toner, print a lot of copies to eliminate toner, and after 100 copies or so, the spots disappeared
