We are getting a Scanner fault after booting up the machine and often have to turn the machine off and on multiple times to get it to not read a Scanner fault.
Also it is not showing any error codes and lastly, not sure if there is any correlation but I can only scan one job before it says I am out of memory. We looked thru all the options and couldn't find any working solution in the admin panel nor online.
Thank you
Thank you
