Booklet Finisher for Xerox Altalink C8070?
  • Albert Lee
    • Mar 2017
    • 27
    [Misc] Booklet Finisher for Xerox Altalink C8070?
    Hi guys
    I just ran into an intriguing issue. I got 3 A-FN07 booklet finishers to pair with Alatalink C8035 and C8070 machines. After some testing, I found that all these finishers work with C8035 with no glitches. However, if I attached the same finishers to C8070, the paper stops at the bridge unit. Adjusting NVM value didn't yield any improvement to the situation.
    I couldn't find much information by googling, so is it so that C8070 requires different finisher? Which model of booklet finisher would work with C8070?
    Thanks in advance for any useful information.
    Br. Al
  • adriansto
    • 2387
    Re: Booklet Finisher for Xerox Altalink C8070?
    • Albert Lee
      • Mar 2017
      • 27
      Turned out that the cable to the finisher bridge motor was disconnected. Should have read the error code and started from there, but you live and learn.
