xerox versant 180 - dispenser motor
  • Ogin87
    • Aug 2024
    • 17
    hi
    i have problem with xerox versant 180
    the motor of dispenser (black) is not working well
    sometimes works sometimes not
    I think the problem is with the power supply because the (24 volt) for the motor sometimes work sometimes not
    but i dont know which power supply to be replaced
    thank you
  • adriansto
    • 2387
    LVPS1 deliver 24 volts but for all dispense motors using Paper Handling pwb.
    So check first Paper Handling PWB or toner sensor in dispense
    • KayleighCollins
      • Jan 2025
      • 2
      Use the machine's built-in diagnostics (accessible through the service menu) to check the operation of the distributor motor and check for any error codes.
      • xcopytech
        • Aug 2006
        • 1794
        Did you test dispenser motor from diagnostic?
        What kind of problem you have?
