Xerox special diagnostic mode for altalink series
  • mindhunter
    • May 2008
    • 142
    Hi guys,
    I am aware that if you want to enter the diagnostic mode you should press and hold home for 7 missisipi and then press home or power button.
    But i am curious is there any other way to enter to diagnostic mode with more privileges? For instance to change some nvm values that are read only in normal diagnostic mode are impossible.
    Or for example in in ricoh copiers if you login with 608182 , some options are not available but if you login with 147 some options will be added to system sp.
    Is there this kind of superadmin login to diagnostic?
    Is there other kind of reserved user like admin Exists in altalink series ?
  • Gaffers01
    • May 2011
    • 333
    No not that im aware of
