xerox 6705 wide format problem
  • RIAD PRINT
    • Nov 2024
    • 6
    I have machine Xerox 6705 wide format, I have a lot of problems with it
    one of them, when i enter ID administrator " 11111 " not work
    show: " You have made the maximum number of attemps to access the system.
    Access denied. "
    from IP adress too,
    what i need to do
    Please any solution
    another problem when i setup the machine with IP like 192.168.1.7 port 80
    and my Computer with same IP and port by default 9100 wont work i don't know why, all my setup correct
    DATA off
  • xcopytech
    • Aug 2006
    • 1794
    User admin
    Pass 1111
    From machine UI
    Pc and 6705 can not have same ip address
    ​​​​​for example you must set pc at 192.168.1.7 and 6705 at 192.168.1.8
    And for print must use lpr and correct queue name
