V180 OHCF tray 6 "broken" related to error 078-251
  • ManassasRalph
    • Oct 2007
    • 18
    V180 dual tray OHCF. Tray 6 reports as "broken". Error on display is 078-251. Can these two be related?
    Any help appreciated,
  • adriansto
    • 2384
    Re: V180 OHCF tray 6 "broken" related to error 078-251
    Sent you mail.
    • JR2ALTA
      • Feb 2010
      • 2031
      Originally posted by adriansto
      Sent you mail.
      Mind sharing? This site is a resource for searches as much as direct inquiries.
      • adriansto
        • 2384
        I sent him service manual to read about the error code. Was not a direct answer !
        • ManassasRalph
          • Oct 2007
          • 18
          Mystery Solved!
          Once I received Service Manual + RAP 078-251 from Adrian Stoicescu (stoadis@gmail.com) started looking at the Tray Shift Screw.
          The bearing for the Shift Screw had moved out of place, therefore letting the gear move out of place, and not homing the tray.
          Once the bearing was put back in place, tray homes, problem solved.
