Altalink C8070 Color Drum is not Spinning
  • Sunrise
    • Jun 2011
    • 16
    Just replace all New Drum working fine and suddenly printer start making sound when print Color print and only came get b/W print no color when i see color drum i see it's not spinning restart printer many times still no error in printer, but drum is not spinning only un color B/W print perfectly fine without any sound from printer.
    thanks in advance for all help i can get.
    Most of time when i print in color mode it gets stuck or came out B/W print or copy only.
  • adriansto
    • 2384
    There is separated motor for color drums also separated motor for color developer units.
    • Sunrise
      • Jun 2011
      • 16
      should i get error for this if not working as i don't get error
      • xcopytech
        • Aug 2006
        • 1792
        drum dev drive.pdf
        Check drum developer drive
        • Sunrise
          • Jun 2011
          • 16
          Thanks For help i open back and i see Motor is moving but Drum is Stuck will remove Drive unit and see will update tomorrow.
          • Sunrise
            • Jun 2011
            • 16
            Can you please give me part number for it as i found drive motor is not working i need to replace DRUM DEVELOPER DRIVE
            i found this on Ebay but its show part number 007K19652 is this correct part number
            thanks
            • xcopytech
              • Aug 2006
              • 1792
              Check pdf file from my previous post
              • adriansto
                • 2384
                thanks
                For C8070 pn = 007K98472
                • Sunrise
                  • Jun 2011
                  • 16
                  I cannot find this online can you share where I can buy this
                  thank you All your help
                  • adriansto
                    • 2384
                    MachinesXerox® AltaLink® C8070Part Numbers007K98470 007K98471 007K98472 007K98473 007K984734Parts ListPL 3.3 item 1 (8070 only)Quantity / Box1 x drum / developer drive assembly per carton.Support & DriversXerox® AltaLink® C8030 C8035 C8045 C8055 C8070 Support & DriversBrochuresXerox® AltaLink® C8030 C8035 C8045 C8055 C8070 Manuals
                    • Sunrise
                      • Jun 2011
                      • 16
                      Thanks for quick reply
